Behind the passenger-side kick panel (just in front of the front door) if you have the 6-speaker mid-line system (has 2 small speakers in the bat ears at lower front corner of front door windows). You don't have an amp if you have the base system (4 speakers total - no bat-ear speakers).
So base system doesn't have amp, would u know reason for no sound coming from speakers but car radio turns on?
Are you saying you have the base system? If so, check fuses 19 and 4. If midline system, also check fuse 18.
Do you have cassete or cd slot in the radio? If so, try that source for speaker output. Otherwise, could be speaker wiring harness disconnected at radio or problem in antenna amplifier or antenna wiring.
It might help you to download the FSM: 2nd Gen FSM Factory Service Manual and 42LE Transmission...
Section 8W contains the wiring diagrams. There's a subsection on the audio system within section 8W.
Cars without the Midline or Infinity I or II don't have an external amp and the radio itself has a wimpy built in amp.
Check the fuses as indicated above by Peva. If you don't have an amp and your radio has power/display then the only items are a disconnected antenna for AM/FM or the radio itself is faulty.
For 2000 there are two 7 pin connectors on the back. The black one is mostly speaker outputs and the amp enable. The gray one is a few speaker outputs and power, etc. Make sure those are connected.
And before we go off on a tangent this is a factory radio right? Not aftermarket?
Replace it
