Hi, i finally found a nice & cheap set of used 1st gen ES wheels (like these
) but i need lug nuts for them.
What type of lugs are used on these? the ones with the "conical/tapered" end or the ones with the "ball/radius" end ?
I would suspect the "conical/tapered" ones but just wanted to make sure before i order some.
What about the fitting size ? 12mm x 1.5 ??
Thanks for any Input
Should be easy to tell just by looking at the holes......should be the conical/tapered ones..
Yes should be easy.... but i don't have the wheels yet... they are still en route to me, and i want to have the lugs and everything ready when they show up..
Tapered ones
I use the tapered ones. Lately, I've also had to put anti-sieze between the taper of the lugnut and the aluminum wheel. (On the outside, not on the thread)
Hardwarz
