1 - 20 of 22 Posts
Can someone explain why when I ran my vin for options this was there.."Delete Rear Stabilizar Bar"? I'm assuming that now I don't have one... should I install one?
That rhythm is INFECTIOUS.
Used to be a standard option, IIRC. Left out in later years during the decontenting days. No more illuminated light switch, no more glove box light, and so on...
Put one in for some better handling.
get off my lawn
a lot of 04's came from the factory that way, it was the final days of Mercedes sucking chrysler dry, get one at a yard 15-20 bucks they all fit 1998-2004
cool thanks gonna add that to my list.
Oh just another quick question... I see alot of mentioning of Carlisle and Danisle (same place?).. I'm assuming this is an annual meet?
Danisle = Daytrepper's (Dan's) meet in SC, it was formally held in Ohio(I miss those :( )
Carlisle = National Mopar show held in Carlisle, PA
If you're going to install a rear bar you might as well put a 300M Special one to make it worth your time. You will need the bar, the mounts, new sway bar end-links, new bolts and nut clips. It would be well worth the mod though.
Edit the post above, Carlisle is in PA. not VA.
you wouldn't be able to toss some part numbers my way?
Already got Rear bar and bushings from another post..hoping they are still the same price.
Oh and would I need to change anything in the suspension? springs, struts?
If I think about it tomorrow I will. Rear special sway bar is a no-go these days, they sold them out. You need all that I listed in the first post and that's it.
there is still some places selling them dodgeparts.com etc... gonna try dealer tomorrow... just wondering if I do this upgrade can I still drive with stock front sway until I upgrade that one?
Discussion Starter #14
wicked! another thing on my list to do
so far got
Auto headlight, 300M seats, Move my amps, & sway bar.
1st Gen FTW - It's AutoMedic!
The parts inventory is known to be off. The order gets placed, then will be canceled. If you find some, let others know.
I wouldnt waste your time. Mopar stopped production a little before last year and as far as I know, inventory has dried up. Your better off scouting junkyards to see if they have any Specials in stock.
I still have both my front and rear special sway bars sitting in my basement, just another thing on my to do list. I suppose those are a valuable commodity these days, but I picked up the rear from the dealer a long time ago for the dirt cheap mistake price.
1 - 20 of 22 Posts
