1 - 12 of 12 Posts
I just upgraded from 98 to Win2KPro....with the exception of having to uninstall my Easy CD Creator and re-install it, everything works (surprisingly)
Anyone have any problems with this OS? Any suggestions? Just started the class today, so I'm just learning about it now. I was going to install Win2K Server, but it wouldn't let me update from 98. I didn't feel like having to reinstall every little thing on my computer, so I just went with 2K Pro. I'll get around to installing Server later (when I take that class) I have a 3 (soon to be 4)computer network at home, so pretty soon I'd like to have a central server running a couple workstations to practice on.
Originally posted by Intrepid98:
Nope, never had any problems with Win2k :) Once you start using it, you'll never want to go back to 98 ;)
True that! Win2k is a far superior OS to the Win 95/98/me series.
Wait till Windows XP arrives. I've been messing around with the betas and it is a pretty slick OS. Very close to Win2K but with the functionality of the 95/98/ME series. It's supposed the final combination of the two(Where the 95/98/ME branch combines with the NT/2K branch).
But get good with Win2K, XP is very similar.
Buschman
The only problem I have ever found with 2k is its compatability wit Novell <Spit>... Also on alot of Compaq workstations it has some minor problems under intense workload...
Works real good on my Intellistation :) oh and looks nice on my 21 inch monitor... ;) Its my work box though :)
[ August 21, 2001: Message edited by: Si ]
Small problem...
I installed it as a 32 bit file system as opposed to NTFS (since I have it networked to 2 other 98 machines)
Now that I have it networked, when I go on my 98 machines, I can see the 2K computer in Network Neighborhood...but when I try to access it from a 98 machine in Network Neighborhood, it asks me for a password. I put in the admin's password and it doesn't work. Anyone know if there is a default sharing password?
I can go into the 98 machines from the 2K machine no problem, but not the other way around. Otherwise, this OS friggin rules! I am so surprised it took all my hardware and software without any hiccups.
Thanks guys...
Log onto windows 98 with the username administrator or any other name that you have an account setup for on the win2k box. Then it will work.
Randy, you rule!
Thanks..it worked.
That probably should have been the first thing to go through my mind. D'oh! Good thing I'm still in school! Ha ha.. :)
Took me a while to figure that one out as well when I first started using win2k :(
...and no one I asked knew the answer...even some administrators???
Here's one for you... (I keep finding these little "bugs")
I have approximately 400 MP3 files on my hard drive all in different folders by category (ie: a folder for 80's Rock...a folder for Hard Metal...etc etc)
Now as I go into each folder of MP3's, about 2/3 of the files are missing. But, if I right click on the folder and hit "properties", it says that the original amount of files are still in there and the original MB size. The files aren't hidden, because I have hidden files enabled to be seen. So, the computer thinks they are there....but are they?
Luckily, I backed up everything on to CD-Roms before the upgrade....but any insight on this little dilema? Anyone else have this problem?
Well, I have never upgraded from 98 to 2k before. I always prefer a fresh install. Maybe it's related to the upgrade.
Sorry, can't help you on this one??
Hey Intrepidaious,
Force a run of Scandisk to check the file descriptors? Maybe the problem..
I agree with Randy, I always format before
I install an OS or re-install, yeah, its a hassle backing up, but its worth it, just for overall performance if nothing else.
Thanks anyway...if I can't get it to work, I'll just delete the folders and copy them back onto the machine from my backup CD's...
I agree with clean installs...but since it was 2 AM and I had no clue where half of my drivers are ...I just went with the upgrade. Considering some of the horror stories I've heard about 2K compatability, I think I made out ok.
I'm still liking 2K though...ha ha :)
[ August 21, 2001: Message edited by: Intrepidatious ]
1 - 12 of 12 Posts
