I am having a problem with the drivers side front window. When I roll it down I have to push it, to get it to go completely down. When I roll it back up, it trys to come in to the car. So I have to roll just a little then pull it up by hand a few times to get it all the way back up without leaks... Has anyone had this problem? Any ideas what it is. I have not taken it a part to look at anything. It seems as if it is off the track. The motor is fine.
only way to tell is to remove the doorpanel and physically watch it, but your description makes me think it jumped the track (possibly loose/bent track). if it's out, when you put it back in watch it go up and down a few times, you might have bent the regulator straining it.
