Would anyone know the easiest way to remove tint? It's stating tp peel, it's real old, anyway, to get new tint put on, the local shop wanta the old crap removed, or it's going cost a ton of cash....any ideas?
I'm thinking of removing mine off the driver and passenger front windows. Our fines here just went to $130.00 and if you don't take it off , the third time they stop you they impound your car. A little exteme I think.
Basically what Joe said. Mist the top edge with amonia and use a razor blade to start peeling it back. Keep misting the loose edge with amonia to loosen the glue and work down/accross the window with the razor blade. Once the tint is off there will like be alot of adhesive residue which you can remove with more amonia...
Senior Member
Amomia water and you can use a black garbage bag applie to the window and let let in sun for a while this may help pull of the tint.
