As an alternative to the LED's in the washer nozzles, you could buy the LED screw lights (www.midnightmoose.com) that you can hide behind grilles (or put behind air vents inside the car like I am doing), or that you can use to screw your license plate in.....they work pretty good, and look cool too...
Of course, it wouldnt be that hard to put the nozzles on your hood......just drill some holes in the hood to the appropriate size that will fit the nozzles, and cut the washer fluid tube inside the engine compartment, and hook it up to the nozzles on the hood. You will probably need some more hose, which is available at Canadian Tire, or some US equivalent....Pep boys, or whatever....
