Hey guys. I have a few questions about my wipers. I just got my Multi-Utility switch fixed and and I've been having this problem where even on my low wiper setting they will continuously wipe. Could this be a problem with a motor or connection?
it could be a lot of things. multi function switch, motor, relays, bcm. In more than one cases that I am aware of it turned out to be the motor was the problem because of the resistance the bcm was seeing. In my case it also turned out to be the motor and the problem was fixed when the motor was swapped for a newer used one. however now the problem is slowly creeping back up on me after a couple years. if you can get a new one, go for it.
Yeah, this happened way before I got my new Multi-Function. That's why I thought it was the motor or relay.
It seems to only really happen on my lower 2 or 3 settings. Temperature outside doesn't really effect when it happens.
