The wippers in my 97 Intrepid seem to be a little off when they are sitting at the resting position, one is a bit low the other pretty high. I'm sure I heard once that this can be adjusted but I can't remember how, can anyone give me a quick run down on the proceedure?
Thanks
I did mine this morning because I had the same problem too, remove the both wipers by lifting each arm and pull the little tab outwards to remove them. Next turn the wiper switch on and off a couple of times, replace wipers and they should be in the proper parked position again. The tip of each wiper blade should be about an inch or less from the bottom of the cowl. Hope this works for you it did for me. :dance2:
I'm not sure if the first gen has it, but I noticed durning a meet last year that on the front window there is a little painted spot where the wipers should rest on.
