1 - 2 of 2 Posts
1998 intrepid w/ infinity system
i'm trying to bypass the amp so i get a full range out of my new aftermarket door speakers, i found a wiring chart on here somewhere, but it doesn't match what's in my car, any help
This should be what you need (courtesyt of joekd):
Power Amplifier C1 (white):
01------06
07------12
01 - 18 LG/VT Amplified Left Door Speaker (+)
02 - 18 LB/RD Amplified Right Door Speaker (+)
03 - 18 YL/RD Amplified Left Door Sail Speaker (+)
04 - 18 OR/RD Amplified Right Door Sail Speaker (+)
05 - 18 WT/VT Amplified Low Left Rear Speaker (+) *
06 - 18 TN/VT Amplified Low Right Rear Speaker (+) *
07 - 18 LG/BK Amplified Left Door Speaker (-)
08 - 18 LB/BK Amplified Right Door Speaker (-)
09 - 18 YL/BK Amplified Left Door Sail Speaker (-)
10 - 18 OR/BK Amplified Right Door Sail Speaker (-)
11 - 18 WT/DG Amplified Low Left Rear Speaker (-) *
12 - 18 TN/DG Amplified Low Right Rear Speaker (-) *
* Premium II Audio
Power Amplifier C2 (white):
01-----------11
12-----------22
(pins 3-10, 14-21 are offset)
01 - 16 RD/WT Fused B(+)
02 - 16 BK/LG Ground
03 - 20 DG/RD Radio 12v Output (live when radio is on)
04 - 18 VT Right Front Speaker (+)
05 - 18 DG Left Front Speaker (+)
06 - 18 DB/WT Right Rear Speaker (+)
07 - 18 BR/YL Left Rear Speaker (+)
08 -
09 - 18 PK/RD Amplified Center Instrument Panel Speaker (+)
10 - 18 WT/RD Amplified High Left Rear Speaker (+)
11 - 18 TN/RD Amplified High Right Rear Speaker (+)
12 - 16 RD Fused B(+)
13 - 16 BK/LG Ground
14 -
15 - 18 DB/RD Right Front Speaker (-)
16 - 18 BR/RD Left Front Speaker (-)
17 - 18 DB/OR Right Rear Speaker (-)
18 - 18 BR/LB Left Rear Speaker (-)
19 -
20 - 18 PK/BK Amplified Center Instrument Panel Speaker (-)
21 - 18 WT/BK Amplified High Left Rear Speaker (-)
22 - 18 TN/BK Amplified High Right Rear Speaker (-)
(pins 4-7, 15-18 are signal level input)
1 - 2 of 2 Posts
