1 - 18 of 18 Posts
wtf? HELP
In my auto tech class at the college we have a scanner that you plug into the car's computer and it will tell you EXACT rpms, actual water temp and all sorts of other things. I was bored during class one night so I pluged the scanner into my car's OBD 1 connecter and with my engine idling the scanner read 800 rpm when my tach read 1200 rpm. and when i reved and held the engine at what my dash tach said was 2500 rpm the scanner was reading 2100rpm. Why is it so far off? The cluster has never been taken apart. Why would it be that far off from the factory?
at least its being consistant. always 400 rpm high. You can fix it, Just need to recalibrate the cluster. That requires removing and opening it up though :)
If you're idling at 1200 rpm all day, then you know something is wrong.
Get it re-calibrated if you want, but it's no big deal unless you race a lot.
so does that mean when you redline it, it looks like 6700rpm? or whatever the 3.3 redline is +400...
I think he idles all day at 800rpm but it says different.
Mopar or No Car
It's just the cluster that is off and that shouldn't effect his shift points. The PCM is still keeping an accurate reading - if it weren't the car wouldn't run since the timing is all done from there ...
LeadFootLee said:
so does that mean when you redline it, it looks like 6700rpm? or whatever the 3.3 redline is +400....
I never redline it. But the redline is 5440rpm for the 3.3L because it is not OHC.
lol i never got to 54 its 5200 :) i red line it usually never. i get to like 4000 alot though
i guees it just jumps to 5440 then down. im never looking at the needel when it redlines usually infront of me. because that motor is screaming and everyone is thinking im a jerk off. :)
RJ said:
What difference does it make if you redline a 3.3 or not? :D
Ouch, keep the gloves above the belt.... :rollgrin:
LOL @ RJ, is there a bennifit to not being OHC?
i dont understand ..... is this supposed to mean if you redline a 3.3 that all you get is a loud growl from the engine and no speed. well ifso its true. lmao
theres so many 3.3 bashing threads at leaste 1st gens 3.3 arnt like the mighty 2.7 lmao. talk about a **** box.
a 2.7 could pin ur 3.3 into submission.
RJ has a 3.5, I was just kidding anyways, but I still do think that the 3.3 runs a lot smoother than the 3.5 or at least the 3.5's I have driven
Mopar or No Car
I owned a 3.3L Concorde for almost three years (I still work on it since it's my daughter's) and I've had my 3.5L for just over a year. The only difference I can feel is the 3.5L shakes a little harder because of all the extra power ...!!! :biggrin:
j/k - I really can't tell much difference between the two when it's idling except the buckets aren't quite as cushy as my old split-bench was ... :)
1 - 18 of 18 Posts
