quick questions about rims, can I get rims from another car like for example a mazda, bmw, honda, but as long as its a bolt pattern 5x114.3 right?
Mind the center bore diameter, it has to fit your hub tightly or the wheel won't stay centered no matter how thght you make the lugnuts.
ok I will keep that in mind thanks BJ
Also mind the offset. Anywheel can have the right center bore aand lug pattern. If the offset is extreme in either direction, you could have a wheel that sticks out 2 inches or tucks 3.5. The recommended offset for our cars is about +35.
What he said!!
Yea when i got my second set of rims i got them from a bmw and i had to get a spacer cause of the center hub not fitting tight like bigjim said.
