41 - 60 of 113 Posts
Discussion Starter #43
Where can I get CAI and LED brake light?
Discussion Starter #49
Well time for an update.
A hypothetical upgrade I have in the planning process right now is.....
2.5" Projector housings w/ HID kit in fog lights. Now I know what first comments will really be... But it won't fit. Now this is a problem I came up with and I have decided that with some creative engineering and maybe a couple custom parts it could just work and be rather beneficial. HID kit should be here tomorrow as well as the Projectors in a few days.
The way I see it is that the actual plastic cover for the fog lights are I'd say a little less that 3 inches If I could create a solid mount point for the projector inside of that with a creative outer sealed covering and a completely already focused projector it could work! Haha. It'll keep me busy through my down time!
Items Order/being ordered: Morimoto H1 mini projectors / Premium HID kit forgot the brand.
did u use the glossifier on the Plasti-dip or no? I was thinking of plastidipping my R/T rims and using the glossifier made by Plasti-dip for a little shine.....what did u do? How is the plasti-dip holding up in the snow season? I live not far from u in Indiana and its been a light winter so far but u know that can change in 30 minutes...lol.....Looking good tho!
Discussion Starter #52
No Glossifier. I just straight plastidipped from the can. I mostly did it to protect my chrome in the winter, but it does look rather good when they are cleaned up. It's holding up strong really of course there is a couple rough spots around the outside but that is expect and can be touched up with my left-over plastidip when I have the time!
Discussion Starter #53
Got my H1 HID kit for my fog light retrofit project in the mail today. Using Morimoto H1 projectors with some custom mounts I am planning up.
I installed HID kits in my headlights and fogs on my R/T....not too bad at all...i also used H1's.....looks awesome on mine...I went with a 9600K bulb on both......slightly blue but VERY bright!
Discussion Starter #55
Mine is a retrofit though using actual projector housings and decent size ones at that. Hopefully tomorrow (if they come in) can sort out what my plan is xD
Discussion Starter #56
Got my Morimoto Mini H1 projectors in the mail. I tore my fog lights apart and got some custom mounting and some custom holes but I have them in there! They are huge! Also because they are Bi-Xenon I was able to have them on either the high or low setting and I decided the high would put out more light so they don't have a direct cut-off line. Will post pics tomorrow once I get them restored. I already know they work and fit at least, even in the 300m bumper!
Discussion Starter #57
Just got done with my fog light retrofit. It took a lot of custom work but I was able to cram 2.5" projectors into the stock housings! Because they were bi-xenon I was able to choose whether I wanted a high beam look or a low beam. I selfishly took the high beams over the lows. Here is JUST fog lights on. They have no cut off because it is on High beam mode.
Here is with my spyder halos as well.
They are aimed the exact same way as the stock fog lights were so the are a little more <> than normal headlights
Here is a little close up in the bumper itself
Discussion Starter #58
FOR COMPARISONS
OKAY! I believe this is fog lights only. Notice the <> distance
This is with lows and fogs. Highlights middle more.
And then my high beams which are silverstar zxe and the low beams which is HID. You lose quite a bit of <> distance with highs
