Now antifreeze is leaking all over the ground, a guy looked at it and said that it is probably my water pump- which doesn't surprise me, I know they go out quite often on alot of cars- especially Intrepids. Does this mean that my timing belt will also be bad? I heard that when the water pump goes out, antifreeze can leak onto the timing belt and corrode it. Has anyone else had this problem? If so, how much does it cost- I'm guessing about $400 with labor. Any suggestions? Thanks.
