41 - 44 of 44 Posts
True. I just did not think it would cause my entire car to run like crap lol
The 5 volts the a/c Transducer gets also feeds the TPS and MAP. So yeah if you short out that circuit you will get issues.
Also, I know how the sensors and gauge works. I don't/didn't care about the sensor, I was wondering if you had verified if the engine was indeed running hot via another source separate from sensor. If the source voltage, or bad ground is present than readings can be wrong.
Also, Fan operations for 1g are approx:
Low speed fan on 210* F Off 199*F
High speed fan on 230*F Off 219*F
So 220* tech is still within Chrysler defined operating parameters to an extent. (Assuming you ment 220*F not C.) I would still feel 220 is high but that is a personal opinion. Not Chrysler defined.
Whoop there it is. Same Symptoms in 2nd Gen cars. Lots of stalling, shut offs, poor running, etc when the transducer craps out. It's that time of year you won't need A/C so just keep the transducer disconnected and monitor how the car runs. If all is well then plan on replacing it and working with the different wiring.
  • Like
Reactions: peva
Wonder if you have an A/C Transducer that's starting to go out. Causes problems in the 2nd gen LH cars also.
Ronbo hits a home run!
:bouncgrin
Discussion Starter #44
Yep, it runs like a clock without the transducer connected. Not really going to worry about it for now. I need to do the transmission mount next, probably engine mounts too.
41 - 44 of 44 Posts
