ES and a new chain. Just 80K I thought it could be worn.
I`ll do a Tranny flush while I`m at it. Has anyone done this yet? Any good tips? Thanks to all for some GREAT advice!
I got just about a full second on both 0-60 and in the 1/4th mile. I have timeslips too. I would imagine that any other 3.2 or 3.5 would do the same.The Prowler gears are a MUCH larger change and they only give about .5 sec in a whole quarter mile. OK, that is good but from 0-60 you might see .2 sec change. And that boys and girls is with the high cost Prowler gears. The % change is far greater than any offered by the factory. Don't look for a full sec change with Prowlers, let alone 2 sec off the quarter, it ain't there.
I also read those posts in the Prowler forums. But the problem is that none of them were stock and most weren't natually aspired. Prowlers aren't even getting the same reduction as the Intrepid. The Prowler starts out with the same gears as the 2.7L the 7% reduces ones. Thats because it had to compensate for the huge 20" rims and tires in the back. The 300M guys I honestly haven't heard from because the forum seems to be dead most of the time.The prowler board consensus is about .3 to .4 seconds in the 1/4 for guys with actual track times. Alot of guys have the gears on the prowler board and alot of them run on the track.
So what do you call a 3800 lb. car running 5.9 seconds in the 0-60?Avenger said:HOLY ****, 0-60 in 7.1!!!!!!!!!! That's insanely fast for a 3500lb + car
Question about this post, is this with the Prower Pro gears or the 2.7/Special gears?rman300m said:Some good points turbo. Here is the results from the 300m with the gears he gets a good gain 0-60 but I think he loses some time because of having to make the jump to 3rd because of the lower ratio.
Before
Ok...just got back from the track today. My best 0-60 was a 7.1. I shot three of them, a bad start (8.9), a 7.2 and 7.1. The temp on the EVIC was at 77 degrees and it was pretty humid out. I didn't unload the car of anything it was supposed to have either, so the full size spare was not removed!
DJ....I ran about a 16.45 with all my current mods minus the gears.
After
First Trip_____#1_______#2_____#3
60'________4.263_____2.669____2.645
0-60_______8.902_____7.219____7.193
1/8th time__12.578____10.882___10.841
MPH______67.6______67.25____67.42
1000______15.727____14.020___16.587
1/4________18.3______16.6_____16.5
MPH_______85.98_____86.27____86.22
Second Trip___#1_______#2_________#3
60'__________2.393_____2.412______2.671
0-60_________6.797_____6.836_____7.616
1/8th time____10.365____10.413_____11.473
MPH________ 68.98_____68.82_____65.53
1000________-----_______13.510_____14.682
1/4__________-----_______16.108____17.346
MPH________-----________86.6_____84.37
The machine measuring the run didn't work right on my first run...only captured the first part. You can also see the effects of getting the dual exhaust and TB work later in the run...my numbers really lag at that point. Early in the run however, they are pretty close.
You don't know how badly I want to do that. Anyone have $1500 to donate for "the cause"?Don Hardy said:OK, cut to the chase here! Drag strip time slips DON'T measure 0-60 times! Not trying to call ayone a BS artist, REALLY, but they don't measure that! Come on. And, TURBO has certainly gained a full second, but he has a turbo. Give me the times with ONLY a gear change, if you're gonna call me out. I've been here a long time, don't even want to make waves with all of the good people here, but let us get to apples vs apples. If I'm wrong, so be it, but please let's be sure we are on the same page of rules.
if you can sell those gears for $125 or less, and still make profit off of them, you can make a killing.Mopar4me said:The Prowler PRO gears are nice for racing but I enjoy going down the highway @ 75MPH . On my ES 3.2L, the actual gear ratio is 3.66 with a 32/33, the 2.7L is 3.89 with a 31/34 . I`m going to make a 30/35 gearset out of 4140 ase certified steel, then heat treat. I program a CNC wire EDM machine. You should be able to use the stock chain because of the same number of total teeth. The new gear ratio will be about 4.10. I`ll experiment on my car to see how they hold-up!
This may take sometime so I`ll measure the 31/34 set, then install, have fun, then try the prototype gears.
i will EASILY pay $125 for 0.4 sec in the 1/4I am VERY sure that most other people would agree with me on that.
