Hello:
I own a 1996 3.5L trep with 84000.
After replacing the spark plugs (checked the gap at .035), wires, coil pack, and successfully tested the Throttle Position Sensor, and Intake air control sensor, and the resistant at each injector (12 ohms); I am still getting the bothersome code 43 from the ECL.
The engine idles rough, but there is something funny about it.
While in P or N, it idles rough at around 1000 rpm. In any other drive gear, the rpm's drop to around 750 and it idles rougher. I have not notice any stall while driving on the highway or at acceleration. As far as I am concern, it is normal.
Something else, when I first start the engine, the rpm's jump to 2000 and then drop to 1000.
The scanner indicated a misfire at the #5 cylinder. I tested the spark plug wire signal with an induction light. It missed. I went on to test the spark plug wire for the #2 cylinder and it did not missed. Since the 4 wire connector from the PCM the coil pack uses the same primary connector for cylinders 2 and 5 could it be that the timing signal to the #5 cylinder is bad, because the timed signal to the #2 cylinder seems OK?
I would greatly appreciate any help on this.
El futbolero
El futbolero
