Hello everyone.
I'm going to change the water pump on my 2.7 intrepid.
I'll be reusing everything except the pump.
When it comes to timing the engine before removing the chain, I'm going to turn the timing gear dot to the mark on the oil pump and both camshaft sprockets to their marks too. Then, I will put 4 locking pliers (2 on each camshaft) to prevent them from turning when I remove the chain and install the water pump, so I don't have to take the camshaft sprockets off.
Don't you think the job will be much easier?
Thoughts?
Thanks
Thoughts?
Thanks
