The VR4 is much more advanced that the Stealth R/T.
It had a base price of $40,900 and included aaaaall of these goodies:
-Engine & drive train
3.0 Liter V6 DOHC 24 valve
-Transmission - 6 speed with overdrive
Twin turbochargers and twin intercoolers
181 cu in w/ 8.0:1 compression
Electronic controlled MFI (multi-point fuel injection) with twin spray injectors
320 Horsepower @ 6000 rpm, 315 lbs.-ft. Torque @ 2500 rpm
(capable of up to 750hp with stage 1 - 4 kits)
Engine redline - 7000 rpm
4 bolt main bearing caps with forged steel crankshaft
Full time all-wheel drive with center differential and electronic traction control
Limited slip rear differential
4 radiators with dual fans (engine, oil, and two turbo coolers)
-Suspension
Electronic control for anti-roll, anti-dive and anti-squat
Front : MacPherson struts, coil springs, stabilizer bar
Rear : Double wish-bone, coil springs, stabilizer bar
Shocks - 3 stage electronic control motorized, gas shock absorbers
Computer control with dash selection for two modes (tour , sport)
ECS control integrated to G-sensors, steering angulation velocity sensor and throttle sensors
-Steering & Braking
Power assist rack & pinion
4 wheel steering (same phase) w/ traction control computer
4 wheel disc with 4 piston calipers
Non-asbestos linings
Air pick-ups (4) for disc ventilation
All wheel ABS system with G force sensor, 2 channel system
-Wheels & Tires
18” x 8.5 / Chromed alloy wheels (spare - alloy mag)
245/40R18 Z rated tires
-Safety Features
Dual airbags with 4 impact sensors
All wheel anti-lock braking system
Three point outboard seatbelts with ELR/ALR feature
Side-guard door beams
Front and rear body crumple zones
-Exterior
Motorized computer controlled front and rear spoiler with override
Dual power remote side mirrors with electric defrost
Projector fog lamps
18 ga Mitsubishi Steel with pearl tri-color paint & clear coat
-Interior
Rear window and side mirrors - electric defrost, front and side windows - heat defrost
Removable sunroof with removable sunshade and front deflector
Auto dimming rearview mirror
Auto dimming interior lights with overrides vanity mirrors with light
7 way adjustable drivers seat with 5 way power adjustments
Leather interior seats, steering wheel, shift knob and side panels
Automatic climate control with magnetic clutch AC, manual disable
Electronic pictographic display
CFC-free refrigerant
Power windows with power reserve
Power door locks with security logic
Full function cruise control (two stage with stand-by)
Rear window wiper / washer
Remote keyless entry system
Security system with electronic disable controls and transistor controlled engine disable
Infinity Stereo system (AM/FM-2, Cassette, 6 disc CD changer) 240 watt, 8 speakers, separate amplifier,graphic equalizer, anti-theft control, steering wheel mounted remote controls, diversity dualantennae with motorized mast
Passenger door controls lock out
Auto side window down
Active-aero overrides
-Speed Specifications
0-30 mph............................... 1.9 seconds
minimum stopping distance 122' @ 60 mph
minimum stopping distance 218' @ 80 mph
0 - 60 mph : 5.4 seconds
0 - 100 mph : 13.6 seconds
(stock times)
ateral acceleration on 200' skidpad = .90g
1/4 mile - 13.7 ď©© mph
(stock times)
5th gear rpm - 155 mph
6th gear rpm - 160 mph
Engine redline - 7,000 rpm
Speedometer runout @ 180 mph
-Other specifications
Weight - 3781 pounds
Fule capacity - 19.8 gallons
Drag coefficient - .33 Cd
Wheelbase - 97.2 inches
Length - 179.7 inches
Width - 72.4 inches
Height - 49.3 inches
Interior Noise:
Idle - 46 dBA
Max, 1st Gear - 70 dBA
70 mph - 69 dBA
Computer Control units
ABS, Exhaust, AC (2), Cruise, ELC-4, ECS, Engine control, ETACS, Keyless entry
Lighting, Antenna control (diversity), SRS diagnosis, MFI, Traction Control, 4-wheel steering
Aerodynamics, Auto lights off, Security, Radio remote
