Trying to remove the valve body from my daughter's '95 Concorde to replace neutral safety switch. I have droppped pan(that someone used at least one tube of silicone instead of gasket and light bead) taken all the hex head bolts out of body but valve body will not come out of trans.
Aren't all Torx head bolts holding the valve body together and are not holding body to case?
The trans is still in car and not on bench so it's a little harder... so what's the secret to getting to the switch?
Thanx!!
Thanx!!
